Comparable overall but I'd rather have the 8800. You could make the argument that either card is better depending on application, and the 5670 draws much less power, but it also sacrifices raw geometry performance for shader horsepower.
Overall there is little you can do but not buy XFX in the future if you are unhappy. Trying to point out the flaws in the comparison RMA replacement system for warranty service is like talking to a brick wall. I've been doing it for ages with Gigabyte with absolutely zero progress.
http://www.gpureview.com/show_cards.php?card1=475&card2=623
Check username before replying.
Avoid flamewar.
You clearly don't realize who you're talking to.hee hee, reviews > any amount of opinion
IMO, at least![]()
pixel fill rate won't matter much when you run out of vram for most games at 1600x900 (my experience).
Anyhow, the real world:
http://www.techpowerup.com/reviews/MSI/HD_5670_1_GB/30.html
HD5670 mostly outdoes the 9800gt, and the 9800gt raped the 8800gts320 in it's face.
True, and all we need for our purposes here. They're comparable, regardless whether you like the 5670 or not.
Edit: if it'll help you feel better, the 8800 GTS sells for like 35-40 bucks now.![]()
The main reason I like slightly older cards of comparable performance to newer ones is that the newer ones, while usually bringing refinements to the table like higher DX support and less power usage, often have driver issues with the games that the older card runs perfectly because the games were designed at the time to work perfectly with the older card. This isn't always true but it's true a lot.
Also, I hate narrow memory bus spec on any video card as I am personally very sensitive to stutter. But in most cases, regardless of which one I'd want personally, I think the 5670 is a superior card to the 8800 GTS for most end users.
I think, due to GDDR5 and higher clocks, the HD5670 actually has a slight lead over the 8800gts320 on this![]()
The 5670's 128bit bus is narrower than the 8800GTS's 320bit bus, but the much faster memory means that it delivers the same 64GB/s bandwidth as the older card.The main reason I like slightly older cards of comparable performance to newer ones is that the newer ones, while usually bringing refinements to the table like higher DX support and less power usage, often have driver issues with the games that the older card runs perfectly because the games were designed at the time to work perfectly with the older card. This isn't always true but it's true a lot.
This is something that I haven't been certain of, so I just want to confirm.
My understanding of memory is that memory speed, data rate, and bus width converge to give a final indicator which is memory bandwidth. So the 5670 doesn't get hampered by its 128 bit bus since it has QDR memory, and the bandwidths are the same.
Am I right?
