JustReason
razor1 is my Lover
- Oct 31, 2015
Ok let me try this again.It DOES adjust the VRM loads because of the phases, and that is shown in the earlier charts where it is 50/50 to the latest where they no longer are.
Case in point the July article you link even says this as a section: 'Reconfiguring the power phase controller'
It means more cycle supported for 3 phases and less for the other 3 phases, putting more strain on one group and why you would be limited what you can do outside of reference spec.
If it was simple, they would also had tested OC and compared that as well like they did with reference power, but they did not, nor could AMD distribute much more between mainboard phases and auxiliary.
Before the update reference for 4k Metro Last Light is 79W for PCIe slot, but 4% OC took that to 90W to 95W and real sustained clocks of 1250MHz and 1.05V to 1.06V.
The 16.7.1 reduced the 79W by 8% to 71W and increased by 12% 6-pin (adding more pressure to 3 phases of VRM but acceptable in reference spec), and with compatibility on reduced by 12% to 67W (very close to PCIe SiG spec for 12V at 66W) and increased by 5% 6-pin , none of this tested OC.
Well I learnt something new,I must admit I thought the driver needed to enable the phase power distribution because when used it adds pressure to 3 phases for any models using this circuit-architecture design, and possibly why no sites (only 3 with the right gear and methodology) who can accurately measure the watts has tested this situation with OC (maybe AMD request *shrug*) - interesting that both PCper and Tom's Hardware did not do an OC test when testing the AMD solution even though they did for the launch review and analysis on its behaviour.
Easier to read from Tom's Hardware but similar trend as PCPer:
Well this raises even more why need to see the XFX measured by either Tom's Hardware/PCPer/Hardware.fr, need to see how the phase distribution behaves in normal XFX GTR custom clocks and then OC, still as I say the mainboard is still going to be at least 100W if OC to 1.3V and we need to see how much additional demand it creates for the 3 other phases.
Of course that comes down to whether Buildzoid made a mistake or not when doing his breakdown and identifying the phase split as 50/50 for the XFX.
BTW my initial post that has everyone in uproar regarding watching out for behaviour on mainboard power only says
Context by half is GPU core phases not necessarily watts although they match.
Anyway to re-iterate again my post relates more to running beyond AMD's standard 480 spec meaning OC (such as the 4% and much higher).
The 1.3V related posts are more about being realistic on real-world 24/7 clock-voltages with reasons explained multiple times now including also why it is no longer great for Nvidia and Pascal compared to Maxwell.
Cheers
Edit:
Here is an image showing how the phases are split 50/50 between mainboard and auxiliary for the 'reference' launch 480.
Cheers
Here is your first post here in its entirety:
You did notice the 1.3V?
Good luck running that voltage all the time and not suffering a failure longer term, the power leakage-energy waste-draw must be very high (need one of the 4 sites that has the lab type measurements to accurately report this)
The absolute ceiling so far is around 1.4V-1.45V for Polaris according to some of the best extreme OCers in terms of voltage tolerances and that is with LN2 and only for benchmark world record type attempts, usual suggestion is a max of 1.2V to 1.25V (usually water and ensuring power stage is fully cooled).
This generation of 14/16nm are far from the 28nm in terms of the long term voltage abuse they can take, and even the short term; combination of density-silicon die thermal-electical characteristics-die size.
Case in point Maxwell could volt to 1.5V, now with Pascal its voltage tolerance with LN2 and only for benchmark world record type attempts is around 1.3V
The voltage tolerance is a bit higher with Samsung, but that is still only around what I mention in the 1st paragraph.
But it does show how good the XFX cooling system is, albeit having to run at 100%.
This is why everyone is at your throat. You started in with the negativity right from the start. The last line has a little positive although seems retracted with saying at 100% fan speed. At any rate as I have to keep hammering into the Anti-AMD brigade in the AMD CPU forum section, This is where we should be free from the constant negative AMD bashing. Even here no one was posting the results are indicative of all XFX 480s. You just kinda chimed in on your own and even after the push back you just keep on digging. That hole is getting real deep, not sure if you can get out.
