XFX GeForce 8800 Ultra
shivang222
I was thinking of getting two of the XFX GeForce 8800 Ultras, but was concerned with some of the comments at newegg of this item. Many people said it runs extremely hot, especially is SLi and can even randomly shutdown due to the intense heat...
Anyone with experience.... please help me verify this information...
1 - unless the price difference is minimal you're better off with vanilla 8800GTX's from a price to performance standpoint, or possible factory OC'd GTX's.
2 - Ultras should actually run a small bit cooler than GTX's due to the revised A3 core. All GTX's currently on the market are A2 revision cores, which do not OC quite as well and tend to run a little hotter.
3 - the people complaining probably had questionable case airflow. What case would you be putting these in?
I really wouldn't pay any attention to those new egg reviews for anything. As said before you should be ok.
My stock Evga Ultra idles at around 55 degrees and will hit mid 70s after a long intense gaming session or running ATI tool artifact scan for a few hours in a pretty lame computer case,all this while running stable at 660 core and 1170 memory so I would't worry too much about it.
I have had it running stable at 690 core and 1190 memory but then load temperatures were in the 80s and did not like it much too much so...
I agree, poor case cooling can cause much higher temps, not just in video cards but most other hardware as well.
XFX Support
I personally think the GTX cards are a better option, they are virtually identical. I would go for the EVGA version, because of the step up program, but it doesn't make much difference.
Please don't trust the tools on newegg, most of those kids do not even own the product they are reviewing. I say if money isn't a problem go with the ultras,if you like bang for the buck the normal 8800gtx is logical like a few above posted.
Since it's not an OC'd 8800Ultra I wouldn't think that you would have any problems with heat. In SLi they would probably get pretty warm during some intense gaming but not hot enough to be an issue.
Ah, ok that would make it run quite a bit hotter but I still don't think to the point of having random shutdowns. Just make sure your case is well ventilated and not a mess inside and you should be fine.
