XFX 8800GTS 640MB Issue
Dietsprite
I have recently purchased all of the components to my new pc.
q6600
Intel Extreme series mobo
Antec Truepower Trio 600w
Seagate 250gb hdd
4g Kingston RAM
XFX 8800GTS 640mb
I assemble the machine and go to turn it on. I press the power button and it surges in a way and immediately shuts off again. So I start removing parts to see what the problem is, I remove the video card and it turns on and stays on. I go fish out my 7100GS and plug that in and it turns on and works, I install Vista etc.. It bothers me because just having the 8800 in the slot without the power into it, it still wont turn on. Is my card bad or is my PSU not powerful enough? I am stumped.
The PSU if working correctly shouldnt have an issue. If you have more then one six pin PCI-e connectors from the PSU try the second one. Is it possible to test the video card in another system?
I will see if I have another 6 pin connector, and no there is no other machine to test it on. It still bothers me how just having it in the slot prevents the computer from even starting up.
Then its either an issue with the mobo or the video card (some kind of short). If you live in North or South America I can arrange an RMA so you can send the video card in for testing, start a support ticket at www.xfxforce.com and let me know the ticket number unless you are able to exchange it though your retailer (much easier then exchanging the mobo for testig purposes).
