XFX 5870 problem
fmsrttm
I will be playing and all of a sudden my screen will go to things like this
With Modern Warfare 2, and Left 4 Dead 2 I've experienced the most problems.
I've tried reverting back to old drivers and also trying out the new 10.10 drivers. And it will still crash every so often.
My temps seem to be fine, usually top out at 60C.
Have you put in a support ticket on our support site? If not, please put in a support ticket. PM me your ticket ID.
Check your memory manufacturer's site for the specs for the memory that you are using. Misconfigured memory is probably the most common cause that we have seen of that type of lockup. Make sure that you are manually setting your memory timings and voltage in the motherboard BIOS.
Check to see if there are BIOS updates for stability for your motherboard.
I would recommend staying with 10.10. There should be no improvement by using an older driver. If anything, the opposite.
Last, if you have the option try the card in another computer.
