XFi option in BF2 doesnt work?
Dillusion
I installed my XFi today with my new rig. I installed the drivers from the CD, and when i went to play BF2 i checked the XFi options in audio options, and it says my hardware doesnt meet the required specifications?
Am i being a noob or is there a patch i needa get...
make sure your mode for your XFi is set to gaming mode. I had the same problem when it was set to entertainment or audio creation mode.
..but not if you have a fatality or pro or prem...the latest drivers break the headphone sensing.
did you notice any real difference on the X-Fi setting? I read somewhere that the setting was for the higher-end cards allowing it to utilize the X-ram, which would make the low end X-Fi's not really benefit much.
Between 'hardware/high' and 'xfi' there isnt much difference. My xfi does have a samsung ram chip on it tho.
