Xfer from extHDD->extHDD
d3rkn3ss
trying to transfer files from one extHDD to another, one is a friends. mine is a WD mybook300, his is a seagate, he has had some problems with corrupted files like the hdd is going out. anyways.. when i plug his in the write delay action thing comes up with errors. then i try to create folders alter files on MY hdd and it says it doesnt have the file to create or alter files.. anyways yeah any help is greatly appreciated. thank you sirs and maams
Either his HD or external case's interface has failed.
Your only chance of recovery is to remove his drive from the case and connect it directly to a working MB and this will void the warranty.
Good Luck!
thank you sir, I assumed the case was f---- but wanted a second opinion, thank you.
No problem, but how 'bout I give a little advice........Never buy those "pre-made" external HDs. Buy whatever flavor HD you like and put it into a 3.5" external case.
Most pre-mades come with inferior cases, electronics,1yr. warranty, and if you remove the HD for troubleshooting, it will void the warranty.
Do you and your buddy a favor and buy a HD with a 5yr. warranty, a case with a cooling fan and put the drive into the case for your external back-ups.
It's usually a little more expensive than those bargain pre-builts, but how much is your data worth to you?
Good luck!
Good luck!
First off, this is awesome. Secondly, is it possible to implement a RAID 0/1 device into my home-made external? If I possibly could, can I use a RAID card I already own? Thirdly, how big of a power supply would I need to do this?
They DIY stuff is outta my league. Maybe someone else could help ya out with that.
