Xeon E3 or Core i7
McZ
is it worth the extra cost $65 to go for an Xeon E3 with ECC ram compared to an Core i7?
(Prices are converted from SEK to USD and includes all taxes I have to pay in Sweden)
Common parts for both
nVidia Geforce GTX560(ti worth extra?)
Corsair Hydro H60
Xeon ~$1060
Asus P8B-WS Intel C206, ATX
Intel Xeon E3-1235, QuadCore, HT
8Gb (2x4Gb) Kingston ECC
Core i7 ~$995 (~$873 if I change to core i5 2500k)
Asus P8Q67-M DO/TPM, mATX
Intel Core i7-2600k, QuadCore, HT
8Gb (2x4Gb) Corsair XMMS3 DDR3
My goal is a stable computer that will not crash randomly (my current one does). Will Xeon and ECC reduce the random crashing/freezing? (what else is the point of ECC?)
And the questions
Win7 x64 and/or Linux as host and then Run VirtualBox with different VMs in, Mostly Linux and compiling stuff like Linux from scratch.
Modifying/themeing my Android phone (doing this through a VM)
Software development at hobby level, mostly C/C++ but lately more C# and some Android (again through another VM)
Playing a few games to kill time sometimes, WoW, SC2 and in the future Diablo 3. I have no need to max graphics settings. (No I don't play in a VM :p )
6700SEK (That would be ~1000$) including all
Sweden
CPU, RAM, Motherboard would prefer mATX to get a smaller case later, Graphics card
Antec P180b
Corsair HX550
2 harddrives 1 ssd and one mechanical as local data storage. I have a NAS for other files so there will never be more than 2 drives in my computer.
6) Will you be overclocking?
No I want a stable system
1680x1050 Dell 22"
I'm planning on building it now...
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I want SATA 6Gb/s
if there is a software that can switch between intels built in gpu and the discrete gpu I want that feature to be able to shut down my powerful graphics card when I'm not using it.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes win7 x64
If stability is a high-priority and you can afford to spend the extra cash, then yes the Xeon build is the better choice as Xeon related hardware tend to be more reliable than their consumer counterparts.
Oh and the GTX 560 Ti isn't worth the extra cash over the regular GTX 560 at your resolution.
Thank you for your answer :)
And stability is high-priority so I will use my money on Xeon+ECC instead of going for GTX560ti
One question though.
Is there any stable software that lets me switch between the internal GPU in the CPU and the GTX560 gpu?
if not there is no point in spending money on E3-1235 instead of E3-1230
I know that the Z68 chipsets support that feature but I am not sure whether or not the server chipsets supports that feature. Intel Z68 chipsets are the only desktop chipsets/tech I know that allows for GPU switching.
I have been searching around and I can't find anything that indicates it is working with C206 chipset :(
To bad Asus P8B-M C204 mATX is like $50 more than the Asus P8B-WS C206 ATX motherboard. Else I would have taken that one and then bought the new Silverstone TJ08-E case.
