Xbox 360 VGA resolution
solideliquid
Using a 22" LCD 16x10 monitor what is the resolution recommendation when setting up the Xbox 360 settings (VGA connection)?
Thanks!
720P or 1080i depending on how well the scaler on you LCD works.
1280x1024, screen format: widescreen.
These are the settings that MLG uses for its competitions. Apparently, since the 360 doesn't support any 16:10 resolutions, this is the best set-up.
Here's the link.
I've been using 1360x768 for some time now. I switched to 1280x1024 I THINK it looks better but it's sort of hard to tell the difference.
Thanks for the advice!
I have used 1280x768 on monitors that do not perform proper aspect ratio scaling with good results over VGA.
It is fairly close to 16:10 aspect ratio (1.67:1 vs 1.6:1). It is a slightly taller picture in general, but circles are not overly oblong/ovals using this.
Regards,
10e
