x800xt pe for which system?
Shodin10k
i need help trying to figure out which system i need to put this video card in
system specs:
Pentium 4 Prescott 2.4 @ 3.3ghz (running @ 733mhz fsb)
1gig ram (running @ 183mhz)
9800xt
Sempron 3100+ 1.8ghz @ 2.2ghz (running @ 980mhz fsb)
1gig ram (running @ 200mhz)
6600gt
any help would be appreciated. I generally want the faster of the two systems to have the video card, but any other suggestions are welcome.
I'd say the Sempron system, but either one would be fine. You won't notice too much of a difference between the two.
i forgot to add, the p4 has a 1mb cache, compared to the sempron's 256kb
still would suggest the sempron?
Yep, the sempron is a stronger processor with a faster system behind it, you will notice about a 15% difference between the two.
