-=Antimatter=- said:The 7600GT is faster than both an x850xt and an x1800GTO in most situations.
Marvelous said:I heard it through the grapevine 800XT AGP doesn't overclock as well... So I would probably go with 7600GT in that situation if the cost is same...
x800 cards overclock very well from what I have seen, AGP or PCI-E.Marvelous said:I heard it through the grapevine 800XT AGP doesn't overclock as well... So I would probably go with 7600GT in that situation if the cost is same...
Borgschulze said:x800 cards overclock very well from what I have seen, AGP or PCI-E.
Mine was awesome, but it's an R480.
I've seen quite a few x800 cards at 600/630~ clocks, not sure what they did.. but just saying.PWMK2 said:Well, X800GTO2s are great overclockers precisely because they are R480. But the R430 chips (X800PRO/XT, most X800GTOs) haven't been known to get as good overclocks. They are possible, but not as likely as with X850s.
Borgschulze said:I've seen quite a few x800 cards at 600/630~ clocks, not sure what they did.. but just saying.
firewolf said:I'd get the 7600GT, it runs on half the power of most other cards and can overclock a lot (especially with a volt mod), plus you get SM3.0 support. Performence is so close between them that the other benefits make the 7600GT worth it. My freind bought a VF900 and took off the fan, the card stayed very cool with only passive cooling.
Marvelous said:I would say it would depend entirely on what games you play...
Games based on Doom Engine... 7600GT FTW...
Oblivion, Battlefield, Half Life... 800XT FTW
Everything else kind of goes back and forth....
Domini said:only the x1xxxs are better in oblivion because of the way they do shading. also the 7600gt is on par with the x850xt/x800xt but i would still choose 7600gt over it anyday for the reasons said above
Marvelous said:Not true... x8xx series do quite well in oblivion...
http://www.gamespot.com/features/6147127/p-6.html
You know x800 cards have 16 pixel shaders while 7600GT has 12....
x1800xt is the same... while 1900xt has 48...
Domini said:*sigh* you need to think that your comparing 3 different generations of cards. x1xxxs do things differenctlly then nvidia does. also you cant say a card is better soley on how many pixel shaders or pixel pipelines it has.
Yeah I mean what's going to be the story when Ut2K7 and Crysis are out? How well will the x800xt, x850xt and 7600GT do in those games? Without doubt or question its hard or argue that either card truly trumps another in this segment.Marvelous said:Did I say say anything is better... Fact is 7600gt has less shaders than the x800... Pointing it out for the future... All cards have their strengths and weakness... Notably the 7600gt has a big weakness.. MEMORY BANDWIDTH...
ANd your point? The #'s are there... Click the link... and you will see x850xt destroy 7600gt in oblivion... an 800xl keeps up with 7600GT...
Oblivion is more of bandwidth hog than anything else...
GonzoP said:Yeah I mean what's going to be the story when Ut2K7 and Crysis are out? How well will the x800xt, x850xt and 7600GT do in those games? Without doubt or question its hard or argue that either card truly trumps another in this segment.
GonzoP said:Solid point there![]()
As you say though for those of us not sporting 20"+ monitors and chugging away at a lowly 1280x1024 res we can still get by nicely with cards such as these; probably even once Crysis and UT2K7 are out.
And I'm sure you will tooPWMK2 said:Yup, this is all part of my dastardly plan to play Crysis on an AGP card...![]()
GonzoP said:And I'm sure you will tooTechnically you're exceeding the minimum requirements. I mean shoot even if we need to run 1024 res its still Crysis
