- Aug 22, 2011
I've got an i7-920 setup (the one in my signature) and I was running a 6GB (3x2GB) Corsair Dominator 1600MHz kit. Since my Ivy Bridge system is now my daily-driver/primary gamer, I'm thinking about relegating the Bloomfield setup to virtual machine sandbox duties and occasional gaming when friends come over.
I want to increase the memory, but let's face it, 24GB triple channel kits are insanely priced and buying two 12GB kits isn't any better. For an experiment, I tried using 3/4 of the Samsung sticks I had in the Ivy Bridge rig to see if they would work in triple channel mode (they are from two dual-channel kits) and so far they seem to be doing fine, though outside of loading a ton of virtual machines or letting it crunch away on Memtest, I'm not sure what else to do to ensure real stability...Perhaps Prime95 or IBT, even though I'm not concerned about the CPU OC's stability?
Was the marketing for triple-channel kits just hype? If I can reasonably expect the system to perform, I can snag another used kit of the Samsung memory for much less than either true triple-channel option.
The other question that I have is about increasing the voltage. I have seen it recommended in quite a few places to bump the voltage to 1.6 or 1.65V if running the system with all six DIMM slots populated. Is this because of the memory needing the extra voltage to maintain stability or because of the memory controller?
These Samsung sticks are currently chugging along at DDR3-1333 8-8-8-22 and 1.25V. This is what the BIOS defaulted to running them at and I don't think it is negatively impacting performance in any way so far. I have seen people online overclocking them to DDR3-2133+ at 1.6 - 1.65V, so I imagine they could handle it, but is it likely that it will be necessary?
