X530 Speaker PROBLEMS
shockerweb
hi all, i have a logitech x530 speaker from the 5.1 system that emits a very weak or no sound when the rest of the system is blasting. I unassembled the speaker and saw no physical damage. I showed it to my father and he said the resistor may have gone.
i have some pictures showing the speaker,
i was just wondering if i could get that resistor at radioshack and what else i would need if that was the problem... thanks alot
http://img303.imageshack.us/my.php?image=speaker8vd.jpg
http://img452.imageshack.us/my.php?image=speaker37yf.jpg
You may be able to purchase the cap from radio shack, just remeber to match the values displayed on the cap or things may go sizzle :eek: . Another place to try is www.newark.com, give them a call and they may be able to help.
Don't all Logitech X-530 systems have a two-year warranty?
Mine does (says so on the box). That is of course, assuming you don't take them apart. I'd have just called Logitech for an RMA. I don't think they've been making them for two years.
