x470 or x570 Pcie v4 is not needed
Discussion in 'Motherboards' started by EmualDave2k12, Nov 29, 2019.
  1. EmualDave2k12
    EmualDave2k12 n00b
    27
    Jan 19, 2016
    is there any other benfit than pcie v4?
  2. Mchart
    Mchart 2[H]4U
    3,598
    Aug 7, 2004
    X570 boards are required to meet a higher quality level for both power delivery and the new PCI-E standard. So about the only benefit is that you know it will support, for instance, a 3950x without the VRM's overheating.
    That being said, most of the similar priced X470 boards also have adequate power delivery.
    So there isn't much benefit, really. Just make sure the board you are looking at has the power delivery to support the CPU you are looking at and get whatever is the cheapest.
    All of that being said, it is highly likely that X570 will be compatible with the 4000 series CPU's in another year as AMD has always said the AM4 socket would last at least until 2020. It's unlikely the older platforms will support the 4000 series given the higher quality required out of X570.
    Really the only reason to buy the older platform boards at this point is if you aren't going to be running the 3000 series CPU's, and just want a solid board for the 1000/2000 series.
    x509 and EmualDave2k12 like this.
  3. EmualDave2k12
    EmualDave2k12 n00b
    27
    Jan 19, 2016
    well said, thank you
    the only thing scares me of x570 is the chipset fan if it dies, but upgradability is important factor.
    I am planning on R7 3800x, and would get a mid range x570 for upgradability only.
    Best of luck to all
  4. matt167
    matt167 Gawd
    861
    Dec 18, 2016
    Midrange B450 can handle a 3800x as well if it has good VRM cooling
    Get the 3800x soon, as in today or so. Because Newegg is selling it for the 3700x price for BF
    crazycrave likes this.
  5. crazycrave
    crazycrave Gawd
    565
    Mar 31, 2016
    even says 2 free games with the 3800x
