- Apr 12, 2003
02G9. Shipped to me this way. Should I update it to the latest?
I did and had no problems. Used the HP utility to create the bootable flash drive from the floppy img file that was in the iso of the Intel firmware cd. Had to switch to IDE in the bios, but no other issues.
I believe you, but Intel firmware has been so unreliable, that I wouldn't push my luck by doing the firmware upgrade in a non-standard way.
...TRIM is now an option on there, trim is verified under win7...
