Just got this from Digitimes
"AMD will also launch the Athlon 64 X2 3800+, which will be cheapest dual-core processor in its Athlon 64 X2 line, according to sources at motherboard makers. The unit price of the 3800+ will be US$345, as compared to US$537 for the 4200+, AMDs current entry-level dual-core part."
Now that would then be the proverbial Graal for all OC:s. It has to be a double Venice 3000+ hopefully they will let a X2 4000+ out as well wit the same price dif as between 4200+ and 4400+...
If so I will upgrade (hale ... Ill upgrade any way that X2 38800+ is giong to run in circles around my Winnie 3500+ if corectly configured in load sharing and slightly OC:d *hoping to live in Sweden then so i can use my Vapo ])..
