X1900 underclocked problem
richardg3
Hi guys,
I built a new rig a month back and am now happy with my overclock being stable on my CPU/FSB/RAM, so I thought I'd overclock my graphics card.
I bought an HIS silent ICEQ3 X1900XT 512MB after hearing they were good overlcockers. However - when reading back the clock speeds for both GPU and RAM I see only 499MHz and 505MHz respectively. I should be seeing 621MHz GPU, (1.44GHz/2) 720MHz RAM. Both Powerstrip and ATITool are giving me the same values.
I can overclock the GPU to 670MHz no problem, the RAM seems to be a problem getting to anywhere near 700MHz though.
Does this sound like a defective card? or is there anything that could affect the readings in both ATITool and Powerstrip?
I have the latest drivers on both my Vista and XP drives. I get the same readings back on both too (although I can't seem to get the GPU to clock as high under Vista).
The X1900XT needs the hotkey polling thing running if it is going to kick into 3d mode. I had the exact same problem until I left the polling running. I know, the name doesn't suggest that it controls 3d/2d clocks, but it does.
As for the OC -- 3D mode (drivers) also ups the voltage, which could be your problem.
yea above poster is right, 2D mode is for windows desktop and stuff which will run at 499 and 500, when you go into games it will jump up to 620 and 700, if you leave ati tool on all the time it will usually start up in the 620 and 700 mode or wutever overclock you set it to. Also i leave it on because its keeps the fan speed higher
Its not just the clocks. The problem you are getting is you are trying to push the clocks to 3D levels without ever increasing the voltage from 2D level.
I forget that it is exactly, you will have to search. Now that I think about it I remember the Vmem not being set down from 3D too much,
Anyway, look at you Vgpu and Vmem and then try overclocking
