X-FI with BF2 Problem !
Super KW
Hi
I cant set ultra high with the game ! ihave XtremeMusic and its in game mode but the game wont let me to the ultrahigh setup i get crash to the desktop !! :confused:
i download the latest driver but same thing ! :mad:
I think you need more xram than the xm version has... I think the ultra setting is for the higher models with 64mb xram... like the fatal1ty.
No... I have the Xtreme Music version and I play BF2 on ultrahigh...
hmm.. I set mine on Ultra and have had issues...
what issues? With the original drivers I was hearing some popping noises when a UAV scan would go, but they seem to have gone away with the newer rev drivers...
It would studder... then hard lock on me. which revision drivers are you on? I might have to go back and try it on ultra again if there are newer drivers.
i have the latest driver and ultrahigh wont work !
how you guys able to do this ?
Which PCI slot do you have your X-FI installed into? I had a wierd lockup issue with my X-FI card if I had it in the bottom PCI slot. I moved it one up and have been playing in Ultra HI mode in BF2 without issue.
-E
I can't recall... Although, I am pretty sure it was the second set of drivers (not the ones that came on the CD with the initial X-Fi release)
Just checking, but you are selecting the "X-Fi" under the audio renderer, right?
yes first i select x-fi then ultrahigh when apply the setting = crash desktop
Can you select X-FI and then High... Does that not CTD?
Things I would try at this point:
1. Disable onboard sound in BIOS.
2. Delete all audio devices from device manager, then reboot and select the newest X-Fi drivers when re-installing.
3. Remove BF2 and re-install
I experienced the same thing.
The thing I did to resove was to up my voltage to the CPU.
Hahahahaha.
Ok seriously I was overclocking my CPU and the temps were fine but when I do not give it enough juice, & I have the X-Fi (Platinum) in there running BF2 on Ultra +EAX, it would hard lock the video screen and the sound would stutter and loop.
I noticed that you OC'd your 3800. How much juice are you giving the processor?
I have my FX-55 running at 3.0ghz @ 1.5v.
That works fine for me.
ok guys it works now ultrahigh :D
i used drivercleaner pro and removes all my old audigy 2 drivers then install the x-fi driver again :)
thank you all for the replys
