He said X-Fi owners, not thread crappers.Elderblaze said:eww turn that shit off
When I made the switch from onboard DFI NF4 audio to the X-Fi, I certainly was.Majin said:I just bought a X-Fi Fatal1ty, it arrives from NCIX on Monday.
Did I make the right choice?
Will I be blown away?
Tytanium said:When I made the switch from onboard DFI NF4 audio to the X-Fi, I certainly was.
dderidex said:Disabled. Really messes up the audio reproduction quality on lossless (or high bitrate) ripped files.
Depends on the source entirely.BBA said:I bet you wouldn't be able to tell the difference between a really well processed 128 bit MP3 and real CD Audio anyway.
If you don't believe me go read this months PC Mag. Has a blind test where people bring their own CD's in, the CD's are ripped at three different bit rates and then blind listening test are done on their own music and on the other peoples music...there was nothing better than a 'guessing' success on picking the sources. Very low percentages of accuracy for ALL the people who participated.
dderidex said:Depends on the source entirely.
For 'pop' music, alternative, modern country, etc - I'd agree entirely. It doesn't help that most pop music is terribly mastered, to begin with.
However, MP3, even at 320kbps, has a REAL problem with duplicating certain sounds - cymbals and cellos, for example, sound TERRIBLE in MP3 encoding, regardless of bitrate. Some higher pitches of vocals can be weak, as well.
Ergo, classical music and operas generally are pretty obviously compromised by MP3 compression.
strid3r said:Well said, and I also think it depends on the other hardware in the chain. Just FYI, the listening rig that Maximum PC had setup was an X-fi straight to a pair of HD580s.
Chastity said:The HD580s would have been underpowered straight from an X-Fi, so the headphones wouldn't be as revealing as they normally are. Also, the "blorp in the center of the head" effect would have been in full swing, which is why I love the Cardas replacement cable. Absolutely no blorp, and the soundfield sounds natural, as if from regular speakers. It allows me to use no crossfeed whatsoever.
BBA said:Where can I get this Cardas replacement cable? I might give it a shot to see if it gets rid of the blorp in my Sony's.
dR.Jester said:Do you run your 24 bit crystalizer on 50% or 100%
Its 50% at default but I can't hear much of a difference when turning it up to 100...
Using Sennheisher HD555's.
