p0intblank
- Jun 27, 2005
I looked at the requirements for the X-Fi XtremeMusic sound card and it says it needs a PCI 2.1 slot, is that just a regular PCI slot found on most boards? I'm going to be ordering this card soon to hopefully get rid of the hissing my speakers emit from I think using onboard audio, and I will be re-using the card in my next build. I have the Creative Megaworks 250D 2.1 speakers and an Asus P4P800-E Deluxe mobo:
http://www.newegg.com/Product/Product.asp?Item=N82E16813131492
Will there be any problems with that combo? The only thing that is really confusing me is the PCI 2.1 thing. I've never heard of that before.
Oh and while im at it, is there a different(better) connection that I will be able to use since I'll be getting the sound card instead of the standard green cable? Sorry for the simple terms lol, this is my first sound card. Thanks in advance.
