- Nov 13, 2006
switched to -bigadv today, getting 1hr TPF on a 3.1Ghz i7 920, anything I should be worried about?
If you can do it that would be fantastic and a HUGE improvement. Honestly, you don't need to go that high. Probably 3.8-3.9GHz would be good enough but that's just a wild guess.ok, I guess Im gonna have to re-OC back to 4GHz+
The P2684 should be a bit higher than regular A3s. What is your PPD and how many frames did you complete? What I would do is finish this WU and remove the -bigadv flag if you don't wish to continue folding them. Lately it seems to be hit or miss with the -bigadv WUs. Sometimes you will get one while other times you won't.another quick question, it seems like 2684 doesnt seem worth the effort, PPD lower then regular A3 WUs, do I stick with it or just go back...
Yes, that would be the P2684's biggest asset if we were to consistently receive them. With all the P670x WUs floating around lately though, it's really hard to quantify what is better to run. More and more it seems that -bigadv means big WU and not big PPD, which is what Stanford meant the flag to designate.It should be about identical to regular A3s except for the P670x units. The biggest advantage is that while you are running one for 4 days, you wan't get a crappy P670x unit...
45.40 TPF, 19.9K ppd on one of my machines. I think you hurt yourself starting it at the lower clock speed. HFM's ppd calculator bases itself off of when you downloaded the unit and when you are projected to finish it. Since you first few percent were much slower, you hurt your total points you will get for the unit, which hurts your ppd. You frame times sound pretty good, though.
Edit: just realized I'm responding to an old thread. The 2684 unit discussed here is probably long gone, but I'll just keep talking to myself.
I have one currently processing in a machine with two GPUs that have been working on 353s for over a day. These GPU WUs consume more CPU cycles than any other for the GPU client. Needless to say, the TPF for this 2684 has increased close to the bonus threshold. I got to find some way to reduce the TPFs. It's still a couple of thousand PPD more than standard A3s, but I don't like skirting the bonus deadline like this.That's OK. I've been accused of arguing with myself a lot.
I hate 2684s, I wish the one I'm working on would go away soon.
Massive. It comes out to less than standard A3s for that whole amount of time your client was folding on that WU.if you blow the bonus deadline, what is the penalty in terms of PPD?
Yes, something to that effect.I think the absolute minimum at the cutoff is about 14k ppd....after the deadline it's somewhere around 2k ppd.
right you should be close to 20k ppd on a 2684 with an i7 clocked close to 4ghz. how are your temps? Is your RAM configured properly?
nope im at 87% since the beginning of this thread...
Well did you finish?
I wrapped one up this morning and was promptly rewarded (punished) by getting another 2684.
