No pump noise from mine. Yours should be the same.
I replaced one of the molex pins for the h100's power lead, as it came loose. I can replace the other if you prefer, though it feels solid.
Reason i'd like an H80 is I want to switch to a quiet case, and i do not want to use the H100 top mount option.
I'm in canada, fyi. I beleive i've got the original box, and fans.
Heat: csemoses
Heat: csemoses
