Thanks. I think I have some 2 part epoxy in the garage somewhere.(Mental note to myself to check on this for you.) I have around 200+ random computer cases in my garage, but it's going to take a few weeks to go through everything.
As a repair note, could you just use some sort of two part plastic epoxy, and reattach the broken piece? It'd probably take only a few minutes to test it out and then hours leaving it to dry. Worst case scenario is it breaks again.
Sounds low-tech but it also sounds like it will work. Thanks.I have the exact same problem. I put a suction cup on the door to open it when it randomly closes.
Do you remember where you got that suction cup? Brand?I have the exact same problem. I put a suction cup on the door to open it when it randomly closes.
