- Sep 2, 2004
Seeing if anyone is looking to get rid of one. 2019 model I believe? Goes for $200 new on Amazon.
Edit: Found!
Edit: Found!
I've heard it's one of, if not the best streaming platform as far as support for things like Dolby Vision. Right now I have an mini-HTPC and Windows 11 kinda sucks for that purpose.I bought mine at Best Buy for I think $179 couple of weeks back, But returned it
Mine would not work with Hulu, I called Hulu and was told the device is not supportedI've heard it's one of, if not the best streaming platform as far as support for things like Dobly Vision. Right now I have an mini-HTPC and Windows 11 kinda sucks for that purpose.
that's very strange...I have two of them and have Hulu on both...works great?Mine would not work with Hulu, I called Hulu and was told the device is not supported
Others have said the same and some have said Hulu was a no go ..Mine would load the app but would no go past the logon screen...gave some error codethat's very strange...I have two of them and have Hulu on both...works great?
I wonder what the determining factor is? Version of hulu installed? Version of the nvidia software running?Others have said the same and some have said Hulu was a no go ..Mine would load the app but would no go past the logon screen...gave some error code
Correct. But still the only thing handling all hdr & hd audio at same time. Damn stupid it's up to a 2019 Device to do what can't be done in current hardware.No AV1 support though if memory serves me right. Something to consider as it doesn't have hardware decoders for it considering it's age.
Yep, only device I've found that flawlessly plays back every file I have on my Plex server.Correct. But still the only thing handling all hdr & hd audio at same time. Damn stupid it's up to a 2019 Device to do what can't be done in current hardware.
Just one - you have the Pro (2019) version? Shoot me a DM if so.i have a few do you need just one or a couple? I will have to clear them but i should have 2-4.
