WTB: Mobo for sv24 or small form factor
ptpeter
Hey guys,
I bought this case of the net with the power supply a few months ago banking on finding a cheap mother board for it.
http://www.techreport.com/reviews/2...sv24-front3.jpg
I have yet to really find a cheap small form factor mother board. Im not sure if im looking for the wrong stuff or not, but I cant find anything. I would really really like it if someone out there could help me. The dimensions 10.5" x 7.5" x 6.75". I would like to find a socket A or or 939, but if there is a small intel i will live with that. Any help on this would be great.
I would also buy one from someone if they have one.
Peter
shytfaced
Shuttle makes proprietary chassis and motherboards for their SFFs. I don't think you'll be able to find another motherboard that will fit other than what the SV24 originally came bundled with.
kirbyrj
The link doesn't work for me, but is it something smaller than ITX? Maybe an ITX board would fit in there.
Sheff
Try Kontron or Commell. They're Pentium M and Pentium 4 respectively, but at least the Kontron has AGP.
I used the SV24 to build my Hellraiser Cube. I was debating on upgrading the board to something better, but when the time comes down to it, I'm going to build a whole new mod from scratch.
Good Luck
The SV24 mobo is larger than ITX, so if you can find an ITX board, that will probably fit with a little modification. If you need a real SV24 mobo, I have one I'll sell for $65.
