WTB: low-power fermi-based. GPU, case fans.
omega-x
My 8800GT finally kicked the bucket from 24/7.
Looking for same or faster fermi.
192 core or more.
Fans taken care of.
Trades.
Can offer a fully functional 4870. Never been overclocked, sure as hell can be. has a massive stock cooler on it.
heat: blackomegax
email: ^ at gmail
Omega, I have a ton of 120 mm fans, from cheap to some nice Scythe Silent X fans...Would be interested in trading 3 of the Scythe fans ($20 each retail) toward that 4870...Send me a PM...
fermi with at least 192 cuda cores, I don't think that exists as a passive card but single slot does exist. I have an msi single slot gts 450 and it is not quiet that is for sure. I know sparkle makes a single slot one maybe it is quiet . There is also a single slot gtx 460 if I recall.
I would imagine you won't find any cards that are both single slot and quiet.
I think you will have to pick one or the other.
dont need super-silent fans. just normal not-loud 120's with ball bearings or whatever doesnt fail easily these days. and i only realllly need one to replace a rattler.
Need the fermi more.
I figure, double slot is fine. the 4870 already is and isnt hogging any space it shouldnt.
that dead 8800GT pushed out a few million points using single slot cooling. bigger might prevent such failure :)
really just looking for any fermi at this rate to match the wattage within reason and likely exceed the output.
If you still need fans, i have some from my LianLi pcp50.
PM me your address and how many you need.
