I have the msi k8 neo 2 platnum and it was reading my ram as pc 2700 so i went into the bios and set it to 3200 it rebooted and now it freezes at the post screen just after it does its memory test (it says the memory is ok) i cant get back into the bios cause it is frozen. Does this mean ill have to flash the bios??? reformat and install xp or is there some other way. if i do have to flash the bios does anyone know where id get the dl from how i can tell its the right one and how to do it. ive never done it before and ive heard if you mess up it can even screw the mobo up so bvad it needs to be sent into the manufacturer. I appreacieate your time reading this and thanks in advance.
