WoW [H]ard Guild
Vulcanus said:
is this guild [H]orde only, or alliance?
EDIT: aww wtf it's not on stormreaver?
Stormscale. but you can transfer to stormscale from stormreaver. and it's Horde.
I'm just a member, not in charge of it, but I'm pretty sure it's only Horde. Also, it's definitely on Stormscale and NOT stormreaver. I ended up making a new character so I could join the guild. Turns out I like it a lot better so now it's my main lol.
Stormscale and as the others said, you can xfer to stormscale from stormreaver. However it is [H]orde only (I mean...you could make an alliance, but you wouldn't be playing with any of us). 2 of us have Alliance chars on Daggerspine
Anoesis said:
i'll join the [H]orde Name will be Gorelaxx
alright I'll invite ya as soon as we're online at the same time
(wish you could send invites to people when they were offline)
Im thinking of getting WOW soon, so what should I be for a simple, not too item dependent character that can solo somewhat well (not mobs at a time with no rest, Im not that crazy on being a soloist), and is a class we need? Yes, that sounds very n00bish, but I am at WOW (for now ;))
Pick what you really want to be, we dont need any certain class really. Most classes can solo decently, it all depends on what talents you choose. Any melee class along with hunters are pretty much weapon dependent, I would say casters dont rely as much on their equipment then other classes do.
However Priests don't solo well at all....on the other hand, it's generally very easy for Priests to find groups.
where is everyone at stonemaul? I usually find myself alone or the [H]orde guild are too shy to talk :(
You do mean Stormscale right ? Thats the server we are on.
shiffero said:
my char name is Prokaryote lvl 5 Undead Priest will join the horde
Awesome I'll send you an invite as soon as the both of us are online. (most of the other members can send invites to actually)
i have 3 characters on daggerspine,2 for m and 1 for daugher,alliance,guild i'm in on ther is obsidian circle.
Only thing about our server is that it's a Low Population server, which means less stuff on AH like there are on High Pop servers, which kind of sucks balls
We're getting up there tho. I run Census+, and it's counting around 5300 horde. And according to warcraftrealms.com, the Alliance outnumbers us 1.5:1 or so.
I'd rather that than 45 minute queues
Yeah that's the way I look at it.
And there's more Alliance for me to kill.
I ran the cencus on Warcraftrealsm. and it said we have 13,000+ players which would make us at leas Medium right? Or even High?
I've got some complications going on with my knee injury, so I'm going to be sparse for the next week or so. Hoping by that time more folks will be ready for SM runs.
Sky15 said:
I'm getting there DHalo :)
What level is SM, and by SM you mean Scarlet Monsatery right ? I have 2 quests for there, But I heard that there are some parts which are low level, and then some parts which are high?
I want to join the [H] guild. I'm only a lvl7 so I don't mind changing servers, I just need to know which server to create my next character on. PvP is fine with me, I guess....
I play on Lightning's Blade right now, with a 18 Tauren Hunter, but I guess I could create an alt. You guys are on Stormscale, right? I might join up either today or tomorrow, depending on my free time.
Stormscale
Between 36-40 area.
Yep - referring to the Scarlet Monastery. Which quests did you have there? Anyway, I've been through the Cathedral, Armory, and Library instances, but not the Graveyard. I don't think I would recommend SM runs for any characters under level 36. Most of the mobs I saw were level 35-38 elites. But certain instances have higher level characters than others. The cathedral bosses are extremely difficult to take down - I believe they are level 40-42 elites. Normally it wouldn't be a problem, but after you kill the first boss, the second shows up, res's the first, and then you get to fight both. You need to go through the Library at least once in order to get the key to open the door for the Cathedral and Armory instances (if no one in your party has a key already). I hear folks tend to stay away from the graveyard because the drops and xp aren't as good. I've seen some very good blue drops from the armory and library instances, so I don't mind doing them multiple times.
Sky15 said:
Between 36-40 area.
Damn im only 32 ... oh well Ill get thoose levels so I can do some instance running with the guild, that is if they want me to help =)
I forget the quests ... I have 2 tho ... Ill check when I get home, after work.
Well, if you had some higher levels with you, you could do through no problem. The meeting stone outside it says 30-40, but that is a bit optimistic. I'm 31, and with a few higher levels I'll have no problem going through it. Somebody offered to walk me and a 32 through the other day. SS got raided before we could go though.
FiNaL_MeTHoD said:
Ok I've started a Stormscale Undead Mage, I need to know who to whisper/talk to to get invited. Thanks!
Just about anyone can invite - what's the name?
