WOW and starcraft 2 setup
Special-K
This is for a friend, he doesnt want the best but something great and he wont put more than 1000$, im pretty sure he will be happy if he can get something good under this. He will play WOW and starcraft 2, I never played these game so i dont know what he needs.
1) What will you be doing with this PC?
WOW and starcraft 2
Maximum $1000 CAD with shipping and taxes 5%
3) Where do you live?
Quebec, Canada
4) What exact parts do you need for that budget?
CPU, Mobo, GPU, Ram, PSU, Case, HDD, Monitor, optical
none
6) Will you be overclocking?
I don't think so, he don't really know how.
20-24" 1080p LED
next 2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
none
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
i have both, just tell me the one I need to install
I know about SB mobo recall but i dont care, :)
Don't have time to look up prices but general recommendations:
AMD Phenom II 955 Black Edition CPU
AMD 880G motherboard with at least two year warranty
Cheapest 4GB DDR3 1333 RAM set that you can find.
HD 6850 1GB Video card
Western Digital WD5000AAKS 500GB Hard Drive
Cheapest SATA DVD burner you can find
Antec 520C or 620C Power supply
as a wow & sc2 player I would say danny's definitely on the right track there. Should be way under budget & massaging can be done after you have a parts list of any small issues.
