WoW and SLI, compiled hints list
h0proc
I know there have been tidbits of info floating around getting World of Warcraft and NFORCE4 SLI working together so I started this thread for those "in the know" about what works and what doesn't work.
Currently I have the Gigabyte SLI board but when SLI is active (enabled in drivers) I notice regular FPS loss in the game, somewhere in the 5-10% range.
I downloaded the SLI tweak util from:
http://www.3dchipset.com/utilities/nvidia/sli/slipro.php
and the 71.20 XTremeG drivers and tried to make a SLI profile for WoW but no selection (AFR, SFR) make any difference. Sadly I still get the FPS loss if SLI is even enabled.
Some of the other threads suggest to rename the WoW.exe to doom3.exe or farcry.exe to get the performance benefits but I haven't tried that yet.
Has anyone any extra tips regarding SLI and WoW?
TIA.
No tips, sorry. I am getting excellent game play with my XT PE. I notice no slowdowns, artifacts or hitching at all. I really don't feel that having two graphics cards will make the game any more smooth or enjoyable. Enjoy the game and knowing you have a silky fast computer on your hands.
1) make a copy of the wow.exe file
2) rename said copy to farycry.exe
3) load WoW by launching the farcry.exe
SLI will be active and you will see a performance boost. On my 2 6600GTs the boost isn't huge but it is noticable in high traffic areas.
hopefully with subsequent driver releases less-hackish solutions will become available.
I get the same on a 6800GT...@ 1920x1200. That being said, a constant 60 at that res with 4xAA and full AS would be nice and the only way anyone is getting that is via SLI.
I've tried all of that and it does not appear to be working for me. Are you sure you had SLI running with WoW? Did you test it with the load balancing turned on so you could see? When my load balancing is on it's just solid green bars and I get no increase in WoW FPS with the above mentioned .exe fix.
