Matthew Kane
- Dec 1, 2007
Which 1 of the above brand names are made in Japan? And are they solid state capacitor?
All except Teapo originated from Japan and still are but the other 4 have factories in Taiwan and China.
Different capacitors are designed for different purposes. For motherboards, the ones that wears out the fastest are usually the Low-ESR (equivalent series resistance, an important factor in fast drain-charge situations, like decoupling) varieties. They are used to smooth out the PWM (pulse-width modulation) power signals from the MOSFETS (or whatever equivalent they actually use, could be bipolar or just FETS if they are older boards), and thus you really want the lowest ESR for that size of a cap. Higher ESR means that the cap heats up more due to Ohmic heating (like batteries) when subjected to large drain-charge cycles. This tends to wear them out faster.
The circuit is not critical with what type of electrolytic is used. You can use less then stellar FL's and FC's and still get away with a rock solid working recapped mobo. But I agree with the rest using the right capacitor for the right job in the circuit when required.
Not necessarily. If used for decoupling, larger capacitance values are generally fine as long as the ESR is equal or lower.
There is no decoupling in HH's application. You also don't have to match the microfarad rating and voltage needs to be matched or higher (both of which you need to watch out for as get to high in value you will have problems with fitting the physical capacitor into the solder lead spacings due to size). In more carefully designed circuits where AC coupling or filtering comes right off zener diodes or a rectifier bridge dropping 100% greater uf rated cap's compared to the original may put too much stress on the diodes, SMPS and PC psu's fall into this category. For motherboard's no big deal. For audio applications, no big deal sometimes more of a benefit, but that's all subjective.
