Blazestorm
- Jan 17, 2007
So I really like WHS... the only problem I'm running into is issues whenever I'm backing up access to files on the server slows down to nothing. HD Movies stutter on the HTPC and everything gets messed with.
So my idea was to go this route...
http://www.newegg.com/Product/Product.aspx?Item=N82E16816115031
And have 11 1TB drives, 1 for OS
then 2 Arrays with 5 drives each, so 4TB per array and set folder duplication on whatever files I want, I know that's not a real hardware RAID card, but it's gotta be better than single-drive performance, and it's 16 ports for $400...
I got Intel Gigabit adapters for both the desktop and server, and may even consider one if I build a larger HTPC with M-ATX case... for that as well...
Or if anyone else has better suggestions or ideas...
