Would there be any difference for gaming between an E6300 & E6600 run at same speed
The multiplier won't make a difference if they are running at the same speed as all the multiplier does is set the rated speed. On that note, it takes better parts to get the E6300 at the speeds of the E6600 because it has to put out more FSB than the E6600.
The cache is minimal in difference most of the time. I think the general consensus is only a couple of percent in many cases.
If you have the right memory that is compatible with your mobo, you can easily clock the E6300 high as E6600.
Higher FSB gives you better performance than just multiplier. I would think it would equal out the 4meg cache.
I swear. I can clock my E6300 higher but my ram is really holding me back. Hopefully I can reach 3500mhz ~ 500 FSB next week when I get my new ram in.
