Would my system push a 8800GTX??
jarablue
I have this system:
Amd X2 4200 @ 2500mhz
1.5 Gigs DDR500 pc4000 Ram
Asus A8N-SLI MB
Raptor 10k 75 gig
Audigy 4 w/ digital out
I am thinking of getting an 8800 GTX. I want to know if I my system will handle it or be able to push it enough. What do you guys think?
It will push it. But unless you're gaming over 1680x1050, get a GTS.
Expect a few fps less than similarly clocked Conroe systems... In the area of about 5-10 (depending on the graphical complexity of the scene, the more graphically intensive, the FEWER frames you're going to lose. It's the CPU bound things that take a huge hit when using those 8800's).
I think it would do fine if you crank up the resolution, aa and af. now if you only have a monitor capable of 1280x768, you may want to think twice. I would also think about adding another 512mb of ram if possible as most new games can use it. but 1.5g may be enough...
You should be fine. I had an X2 4400+ and it handled single 8800GTX fine and from what I could tell SLI was fine too. But I didn't have the opportunity to run thoes cards in SLI with the X2 for very long as shortly after getting the second card a motherboard problem forced me to upgrade to the C2D.
O please guys... right now you might not need the GTX, but later when other more demanding games come out and pushes the GTS down to its knees.. you're going to wish you had bought the best you can afford to.. the GTX.
And the cpu thing is overrated.. if you have a decent cpu at least an athlon 64 decently clocked... 2.4+ you're going to be fine.
Well fuck me I am getting a 8800GTX woohoo! Thanks for helping me spend my cash! I have a Samsung 204B 1600x1200.
My gaming is going to be:
1600x1200 w/ 8x AA and 16xAS. All the time.
So with those settings it should be fine right? I want to game at those settings all the time. LMK. thanks!
Forgot to mention I have an Antec Smart power 500 watt. Has been working flawless in my system. Hopefully that should supply it well. Forgot to mention my other 120 gig HD and my DVD Writer. Should be ok though.
Ok for review:
Amd X2 4200 @ 2500
1.5 gigs ddr500 pc4000
8800gtx (will be in system)
10k raptor
120gig seagate 7200rpm
dvd writer
audigy 4
MB Asus A8N-SLI regular
5 case fans
no cpu fan. running fanless sythe rev.b
no chipset fan. running heatpipe
All of this is going to be on a 500 WATT Antec Smart power PSU. Will that be enough for the 8800GTX to run?
Dual 12v rails rated for... What?
I can't find an OFFICIAL specification for the amount of power these put out.
You should be OK with it... But it MIGHT not cut it. I've heard bad things about SOME (READ: not ALL) Antec PSU's and I'm not particularly sure if this is one of them.
I ran a GTS (hefty OC, and a WC system) on a 500w Ultra X connect... With room to spare too, at least 100w.
EDIT: How are your CPU temps with the fanless scythe?
Well I have oc'ed the shit out of my system with my current power supply and it didn't hiccup once. So maybe that will bode well for me.
My cpu temps are exaclty the same as they were with the retail X2 fan/heatsink. Idle is 40c max load with 2 instances of prime95 on each core gets to 60-61c. Not too bad for me. And it is completely silent!!
Why only 1.5 GB of RAM and not 2? You won't run in dual channel memory mode. If you want to eek out the most performance go for 2 GB of RAM.
2 512mb sticks and 2 256 mb sticks can run in Dual channel on some boards...
I have 2 512 and 2 256. that would work fine in any board by the way. I have the exact same memory for all 4 channels.
