dragontales
- Aug 13, 2002
I'm looking to upgrade...
My system is in my sig. Would my system be too slow for the 8800GTS? THanks
What do you guys mean when you say a "vanilla" card?![]()
You can't just say yes or no to that. It depends on the game. Something like rainbow six: vegas will definitely be bottlenecked by your cpu, but some other games propably won't. Depends on your resolution as well.
RainbowSix Vegas? No way is that game that CPU intensive. You'd be more likely to see a CPU bottleneck in the RTS arena. Try Rome or Medieval Total War for size.
Well Running at 1280 x 800 at least it is! In an exactly same spot just standing there with a core 2 duo e4300 at stock fraps said 44fps and at 3ghz it said 74 and at 3,2 it said 78. I also did a little benchamark in a certain level and difference between 1.8 and 3ghz was around 60-70% in fps. And those detail settings in game had little to none affect on fps.
Ofcourse things were a little different at 2560 x 1600, so depending on resolution..
No way! Jesus that's like night and day. I'm guessing at 2560x1600 you saw a much smaller deviation. I never would've dreamed of a 60-70% improvement with an OC alone. I hope to experience the same improvements when I go C2D, but I'll try not to get my hopes up.![]()
I really wish people would realize that at LOW resoulutions that most new games on a 8800GTXS/X will be CPU bound. You only start taking some of the load off your system as you raise the resolution and the image processing.
