Would it be possible to built a small factor pc using wood?
I've been wanting to get a small factor pc, but the cases available now are bigger than a ps4. The smallest pc i can find is the alienware alpha and the sentry is above my budget. I want to know if is possible to just built small factor from wood like plywood. Sketch the pc parts to know where the holes should be place. Has anyone done anything similar using plywood?
A wood built itx case.
Yes. That is one I did. I don't recommend it because you need access to good tools to make the edges fit correctly.
I used hobby grade wood. I don't recommend plywood because with most tools you get splinter pieces.
Have you considered an Intel NUC? I first got an i5 which I really liked a lot. Just got an i7 Scull canyon model and don't think I will ever go back. I will keep my high-end ITX for VR and some games but the NUC is fine for 95% of my uses. It is fast shuts down instantly, boots in under 10 seconds, is very quiet and runs cool. It's attached to the VISA mount on the back of a 43" 4k monitor and turns on and off remotely. Couldn't be more pleased. My ITX in an Inwin 901 case with water cooling and a heavy power supply weighs over 30 lbs, the NUC weighs about a pound.
Yes, but it is kinda pricy. it would be nice if that APU was sold invodiualy so that can i use in a mino itx case. right now, im seriously considering getting alpha because of is size but i would like to try a wood project first.
thehack's post about his wooden case drove me to build one as I had most of the tools needed to do it. I nearly finished it over a weekend and upon testing with all of the components fitted, the pci-e riser cable did not work! I was frustrated and threw it all away and bought a thermaltake itx case on sale. In hindsight I shouldn't have thrown it away cause it was pretty cool (I modeled it from the Dan A4 with a few mods I added from the metal honeycomb pieces I cut out from my old ATX case) and was proud of it.
I say go for it!! Don't buy the $20 cheap riser cables, they suck and take a while to ship!:mad:
What was the mistake that make you give up?
There are i5 and i7 desktop Broadwell CPUs, with the Iris Pro graphics. The newer one in the NUC ends up only a teeny bit better, in games. You could build a broadwell into ITX.
I was reading the forums that the NUC had a CPU with a IGPU that was similar in performance to a gtx 940m that's the main reason I consider buying it.
So I only ask... is a dedicated GPU of any major importance to you. By the sound of it, no... but I want confirmation.
I built my first bitcoin mining rig out of 3/4" MDF back in the day. It was big enough to house 7 video cards and had a custom ducting system that directed the heat out the window. I lined with vinyl barrier and despite high fan speeds it was very quiet and nice and ran cool with my air intake system. Little did I realize I'd soon be build more rigs and did away with the custom box after a few months. But it was cool. I've built a few awesome designs in sketchup for some pretty badass PC rigs that I may one day do in the future. Building your own can fun.
