Worthwhile Upgrade
Are you pursuing a dual-card SLI setup or are you replacing your 6870 with the 7850?
As an aside, is there a typo in your sig? It indicates that you're using a 6970 in your primary machine.
Ah, typo. Was just wondering if it was a good deal. Not looking to replace what is in the current box.
If I do it will be with something else.
I may be looking to build another machine to play DCUO on my TV.
oh in that case, no it's not a good deal considering it's the 1GB version.
