A 4870 512MB versus a GTX 260 192 at 1680x1050? No, you won't see much difference at all. I would not do it.
What about a 260 216? Or will I not really benefit at all with my current res going with a higher end card?
Well I dont want to limit my options to only the 260. Is there any card that will be faster at this same resolution or should I look to upgrade my monitor first?
Upgrade your monitor first. While the GTX280/285, GTX275, and HD4890 are faster than the HD4870 512MB, you'll probably won't notice the difference at that resolution to justify the costs ($250 +)
not as cost effective as yours but better long termI would suggest a hardware upgrade first. For the same $200 you could do this upgrade and significantly improve your performance,
AMD Athlon 64 X2 7750 Kuma 2.7GHz Socket AM2+ 95W Dual-Core black edition $64.99 + fs
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 $42.99 + fs
GIGABYTE GA-MA770-UD3 AM2+/AM2 AMD 770 ATX $74.99 - $10 mir
Total: $182.97
This will keep up with your 4870.
Total: $182.97
I am running an i7 920 with 6 gigs of ram. If you were going by the system in my sig, its way outdated. My other hardware is fine.
