Workstation build
Twikii
My sister recently asked me to help her purchase a new computer, and I asked her if she'd like to have a custom one built, as it could save her money. I'm looking to get her some examples of what she could have within her budget, and have her pick which one she'd like best.
Web browsing
Photo manipulation
She wants to keep it around $500 bucks, but I doubt that'll be possible, as she needs to buy Windows, along with a monitor and some other things. She can afford up to $700.
Utah--would prefer ordering from Amazon or Newegg. Probably Newegg.
Case
Motherboard
GPU
RAM
Optical drive
CPU
HDD
Power supply
Monitor
Keyboard
Mouse
None.
6) Will you be overclocking?
No.
Don't currently have one.
Once she decides on what she wants and purchases the parts, I will help her assemble the PC.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Basic is fine for this build. Possibly USB 3.0, though.
She does not own a Windows license.
Thanks in advance for the help. :)
I'm also asking for advice on my thread about a workstation build.
Maybe someone that answers in your thread will give me a few ideas as well.
Good luck.
Due to the fact that she doesn't have a monitor or OS license, building a PC simply isn't worth it in your sister's case without going with used or crappy parts. So in this case, you're better off with a prebuilt PC. Your sister's budget and her needs doesn't warrant a DIY built PC. In fact, there's a Dell deal right now for ~$480:
http://configure.us.dell.com/dellst...el_id=vostro-260&c=us&l=en&s=soho&cs=ussoho1&
As for the monitor, grab this deal:
http://www.gotapex.com/content/6178...-LED-LCD-Monitor-for-99-99-with-FREE-Shipping!
So for $580, you're getting a very solid quad-core setup + windows OS + high-resolution LED LCD monitor.
Yeah I've heard that when you're looking to keep it in the $600ish range and start from scratch you're better off buying pre-built. Dell monitors tend to be pretty solid purchases too.
Yes...after shopping around at Walmart today I quickly realized it would be cheaper to go with a prebuilt bundle. I'll have her check those links out. Thanks for the help guys, I really appreciate it!
