Today I started the implementation of some components.
For this step of the mod, I prefer to take my time so as not to make silly things, like fixing a component and realize after it is misplaced, ill-fitting ...
Especially since some changes have occurred compared to the basic model of the project: adding a power supply, place of pumps, additional SSD (4 instead of 2), addition of 2 graphics cards ...
Reminder of the initial project:
So this day was devoted mainly to the adjustment to find the right place for each item.
Start with pumps and two additional tanks.
We must position the tanks to prevent them block outputs of the pumps.
After some screwing, unscrewing, rotations ... the correct position is found.
Then I place the main tank and support for various switches.
Then I set the rads
The hold (too long) between 360 rads will be removed. The connecting pipe between the two rads will maintain the gap.
After mounting the rads, I realized that I had forgotten to make a passage for the pipe between the top and the tank => to do
I continued to fix (temporarily) other elements to have a more concrete idea of the result.
+16 kilos compared to the empty box. And it is not finished.
Then I set the rads
