Working Tractor Beam
CommanderFrank
Cat Can't Scratch It
Beam me up, Scotty! Researchers at Australian National University has successfully moved objects with just a beam of light. It’s not quite ready for primetime, but it’s a beginning.
Andrei Rhode and colleagues at the Australian National University say their new laser device can move glass objects hundreds of times bigger than bacteria, and shove them a meter and a half (5 feet) or more. Rhode says the 1.5-meter limit was only because of the size of the table where he placed his lasers.
Well for it to be a tractor beam he needs to figure out how to pull something and I'm betting that's a bit more challenging. ;)
heh. what oldie said. thats more of a deflector dish sort of. change of title perhaps ;)?
Scientists shouldn't even bother researching and developing a tractor beam. Everybody knows they don't really do anything, and are typically broken within 10 seconds of use :)
perhaps the scientists should study marriage. thats one hell of a natural tractor beam if i've ever seen one :p
Maybe the beginning of a force field. :) Better yet asteroid deterrent system.
This really isnt that complicated. It is simply using a Laser to form a "Tube" around an object and heat the air up to levitate and move the object. Think of this more like one of those air-tubes they use at the bank drive through.
I'm also thinking possible force-field application. Instead of direct beam to move a single object, maybe they can make it wide beam and anything in the path of a satellite or star ship would be deflected away.
yes, it would heat up my beer... big faily, I'll stick with the slow-ass robot
eh, scientists have been using light to exert a pressure for quite some time. Hell I believe they even use lasers to help push a "rocket" up a rope in that NASA sponsored event they have every now and then to see how high you can get something without using propellant.
So why is this a "tractor beam"???
It can't pull, only works for small objects at a limited distance, and requires a not volatile gas environment.
Still REALLY cool for use as micro tweasers . .
But come on stop trying so hard to make some lame Sci-Fi link that really is not there at all . . LAME
Asteroids, starships, deflectors... *sigh* Was I the only person to read the article? THIS WILL NOT WORK IN SPACE, PEOPLE!
[SciFi geek hat]I believe that would, in fact, be a repulsor beam, not a tractor beam.[/SciFi geek hat]
Actually, yes, You can increase the air pressure or use a vacuum to move the object inside the "laser tube" either direction. (Push or Pull)
Light Pressure would be similar to Solar Wind, but yes, in this application, it will not work in space.
As in directly towards or away from the emission source?
Besides, if you're manipulating air pressure, that's not exactly a "tractor beam", unless me holding a straw in my mouth also counts as a tractor beam, because I'm sure I can move things both towards and away from the end of the straw that way(as long as they're light enough).
Could you suck a golf ball thru a garden hose?
