TechLarry
RIP [H] Brother - June 1, 2022
- Aug 9, 2005
HP ZR2740w 27" WQHD LED-backlit IPS Monitor with DisplayPort, Dual-Link DVI & 4-Port USB Hub
$349.99
http://www.woot.com/offers/hp-27-wq...il&utm_term=0_c5ca76da11-cf5383e8e1-293440957
Factory Reconditioned
Specifications:
Class: 27"
Viewable: 27"
Resolution: 2560 x 1440
Refresh Rate: 60Hz
Aspect Ratio: 16:9
Colors: 1.07 Billion
Contrast Ratio: 1000:1
Brightness: 50 to 380 cd/m2
Response Time: 12ms (GTG)
Viewable Angle: 178° / 178°
Pixel Pitch: 0.233mm
Panel: LED-backlit IPS
HDCP Compatible: Yes
Input Connector: DisplayPort, Dual-Link DVI
USB Hub: Self-powered 4-port USB 2.0 hub, with (1) USB upstream connector*; (4) USB downstream connectors
Display Features: Plug and Play
Anti-Glare
Stand Adjustments: Tilt: -5 to +35°
Swivel: ±45°
Height Adjustment: 3.9"
Pivot Rotation: Yes
User Controls: Brightness, Source
Physical Security: Security Lock-Ready
Voltage: AC 100-240V, 50/60Hz
Power Consumption: 120W (max) 95W (typical); <2W Standby
VESA Compatible: 100 x 100mm
Inputs:
DisplayPort with HDCP: 1
Dual-Link DVI-D with HDCP: 1
USB 2.0 Ports: 4 (2 side; 2 down)
USB Upstream: 1
Dimensions:
With Stand: 25.4"(W) x 21.6"(H) x 9.3"(D)
Without Stand: 25.4"(W) x 15.4"(H) x 2.7"(D)
Weight:
With Stand: 23.1 lbs
Without Stand: 17.6 lbs
$349.99
Specifications:
Class: 27"
Viewable: 27"
Refresh Rate: 60Hz
Aspect Ratio: 16:9
Anti-Glare
Swivel: ±45°
Pivot Rotation: Yes
Inputs:
USB Upstream: 1
Dimensions:
Weight:
