Wooden Computer Cases
hm, cheaper to build one yourself. the ones on frozencpu.com
look like antec cases with the cheap vynl presson crap
I think that the design I came up with for my case, will be made of wood, once Im finished making real scalable drawings and stuff I'll show you if you want.
eww wooden computer cases ?
most likely not a good idea if possible. Your motherboard and all sort of has to be grounded and wood isn't very good for that.
I can't imagine a case completely wooden unless it had a aluminum tray inside or something.
I think you are wrong about that. If the motherboard was grounded through the mounting screws, then how would it function in situations like an acrylic case? Or a case with plastic standoffs for the motherboard? I believe that all the components are grounded by the power supply; hence the ground wires in the ATX connector, molex connectors, etc.
I have been thinking about making a wooden comp in wood shop. I should be done with my project soon and I need something else to build :)
I think it would look pretty sweet, just dunno how to design the front bezel.
EDIT: I think I read somewhere that metal cases are overall cooler (colder) than wood? this true?
Correct. A modern day mobo grounded through the case will not even boot up (safely at least)
I think a wooden case would be a great idea. Get a decent type of wood and try out some paint or stain. I once saw a wooden atx case that had a distressed ivory look. It was disguised as a bench and was even sturdy enough to sit on.
edit: grammar
Yes it is a nice idea, but what type of cooling do you plan to have in there? Wood isn't the best for cases, thermal wise. Tell me, is this for a HTPC?
wooden cases are totally fine. I would recommend solid wood, but veneer is ok I guess :/ Dont worry anymore about heat than in any other case, the wood wont affect it enough to notice, of course, normal forced ventilation is still a must.
Yeah I was planning on putting several fans in it, and building it around good airflow. Might include water cooling for the summer too :)
the material the case is made out has very little to do with cooling. UNLESS the hot parts are TOUCHING the case ( using the case as a HS )
The grounding issue has been touched before, every thing does ground through the ground wire->psu->outlet. But as an additional precaution many things ground through the case->psu->outlet as well. They'll still work and all without the metal case, it's just supposed to be back up of sorts. I havn't removed the ground cables from anything though so I don't know how effective it is.:rolleyes:
Then again I've heard stories about temps rising from adding Dynomat. Alas, I would thing the parts arn't touching that.
I just saw a "the screensavers" episode where Yoshii made one, he but veneer on plywood, but it still looked pretty damn nice. even made the power button/optical bezel out of wood.
linkage
blocked cooling? my case never gets hot enough to be used as a cooling device
Hmmm... As per cooling, might the wood insulate the case better than metal? Thus allowing for increased temperatures if you had insufficient airflow?
Anyway, a wood case is a great idea. I've been wanting to do one myself for a while.
Originally posted by Quester
check out these guys for wooden computer stuff !! crazy Swiss
http://www.swedx.se/
.SE is sweden. switzerland is .cz
but anyhow, i've seen a $400 keyboard made out of maple with the keys and everything in wood. the letters were burned on. it was so well made it was frightening.
:D :D :D .cz is Czech Republic...
Switzerland is .ch :eek: :eek: :eek:
Thanks for all your help, but I am not planning on making a wooden case but buying one.
I need one for my Dad's office (which consists of nothing but wooden furniture, walls, fans, etc....).
Do any of you know where I could buy one?
no.. it's real wood.
He cuts his own and over lays it on the case.. he has a nice description of how it is done.. but it's still the real thing.
I personally like the Leather covered Harley case !!
looks like i'm going to lowes to buy some wood:D
hey in the wood pc that yoshi made he use a mini-itx with a built in psu:eek:
there only $180. not bad
VIA EPIA TC
hey in the wood pc that yoshi made he used a mini-itx with a built in psu:eek:
VIA EPIA TC
Any one keen on doing a wooden mouse? I'm trying to work out how to do the buttons.
To touch on the grounding issue it isn't required to have a functional computer, but encasing a computer inside metal protects it from outside interference, and reduces the interference it creates.
