Are you worried about the thermal logistics of using wood? I thought most computer cases use aluminum so that even the case material itself will act as a heat sink.
Agreed. I've made rough prototypes from cardboard before committing to aluminum and the temps are nearly identical. Air flow rates through most any case will negate the case material's thermal conductivity properties. And it's thermodynamics, not "thermal logistics". /eng. know-it-all rantWhat a PC case is made out of has an insignificant affect on overall rig temperatures.![]()
