SilentLunatic
- Oct 19, 2002
Also, does flipping the switch on not cause a voltage drop?
It likely would work but for a lot of reasons too long to go into its not a good idea to use the case ground this way.do you wire the Red wire from the fan to the switch then to the motherboard and ground the wire from the switch to the case?
