- Jul 17, 2006
I got the rest of the holes cut. Above the I/O shield, I cut a little hole where the power connector plugs in. You can also see where the 2.5'' hard drive mounts inside near it. The top hole is for the fan and radgrill, and the front holes are for the LCD and power button. Next, I am going to finish sanding, get the plexi-glass cut, and primer it to get ready for paint.
