I just finished setting up my rig and go to install win7 x64. Everything runs smoothly until I get to the wireless card. From install it works perfectly. But after I ran Windows Update now my computer cant find it anymore. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I went into the device manager and found a misc. PCI card, which I'm assuming is it. But I cant assign the drivers from the driver CD (it says it cant find any one it
), and I've tried assigning drivers to it manual from the list available (Ralink b/c I'm pretty sure thats what Rosewill uses anyways).
Does anyone have any other suggestions before I RMA the card?
In case you need to know it:
i5-2500k
ASRock Extreme 4
1.5 TB Seagate
2 x 4GB Corsair XMS DDR3
Much appreciation in advance for you help fellow [H]'ers,
Forkedt
i5-2500k
ASRock Extreme 4
1.5 TB Seagate
Forkedt
