TechStuey05
- Aug 5, 2005
Hi, I recently bought a new computer and I moved my Apple Computer upstairs. The Fios Cable modem/Router is downstairs. For internet, one option is to use a wireless adapter, the other is to run a 125-150 ft ethernet Cable from the Cable modem/Router to my Apple Computer either inside or outside the house.
I bought a wireless adapter (Amped Wireless High Power 300 N 600 mw USB Adapter) but my internet downloading and browsing seems slow. I believe that I'm also getting interference with my Mighty Mouse.
Sometimes I lose internet connection and I have to unplug the cable modem and plug it back in before I'm able to reconnect the wireless Adapter to the internet.
My Might mouse seems to lag and isn't accurate since I hooked up the Wireless Adapter. When I powered off my Might mouse and powered it back on sometimes my internet connection is lost but the mouse suddenly works perfectly.
Should I try a different Wireless Adapter or should I hook up a 125-150 ft ethernet cable to my Apple Computer. A direct connection is faster which is what I would prefer but can there be signal loss with such a long cable?
I would have to either bring it around the house and into my room or make a hole and go through the closet into my room. Can Ethernet Cables work outside with the cold, heat, storms, etc?
Thanks
Thanks
