wireless mouse (gaming?)
Hey [H], Im looking for a mouse to be used by my lan pc. I really want it to be wireless so when I have to trans port it all I have is 3 cables (power pc, power monitor and monitor cable) so I have a wireless keyboard, but now I need a mouse.
Right now on my main computer I use a razer deathadder and I love it. I like the size and I guess if you had to name the grip I have it is a claw grip. I'd like to spend less than $40 but I can go higher.
werzinator
Many $40 wireless mice are very small and are nearly fingertip grip.. primarily meant for laptops.
The Logitech M705 is in your price range when on sale, but I don't know how well it performs when it comes to gaming.
Are you looking for strictly wireless/battery powered, or the ability to act as wired and wireless?
MacLeod
I suggest checking out the G700. You can use it wired or wireless and its works just as well either way. Solid battery life like 8-10 hours of gaming and an extremely comfortable shape. I think my DeathAdder is the most comfortable mouse ever and I like the shape of my G700 a lot too so you might as well.
mavrocket
Logitech G700
Get the non-S version (same exact thing) for about $20 less than the newest rev and you are good to go.
I bought one refurbed off of Newegg for around $50 and haven't look back since.
so it seems the g700 is the way to go. $60 on amazon isn't bad. thanks again.
I would prefer it to be wireless all the time only going to be using it when I'm brining the computer to a friends house.
Also, are there any good Bluetooth mouses?
gankernation
I used to have a logitech wireless mouse for gaming. There will be some time when the mouse would just turn off in the middle of a game. Very frustrating! I believe a simple regular wireless mouse might be better unless you're going to be playing MMOs and need the extra buttons.
sharknice
The Logitech G700s is the way to go if you want a wireless gaming mouse. But full retail price it will cost you $100. I would probably try to find a used one or see if you can get one on sale.
Cheap wireless mice tend to have a lot of problems with interference and dropping signals which causes lag or erratic movements.
So if you want one for only $40 you'll have to be willing to make some compromises in performance.
D
Deleted member 267955
Guest
I just to use the Logitech G700. It was a good mouse, however, I noticed in gaming situations (a lot mouse movements) there would lag. Not good. In the market for the a new mouse now...
sharknice
I find that strange. I've never had an issue, or heard of anyone having one before.
MacLeod
Never had one with my G700 either. May have got a lemon cause mine works just as well wireless as it does wired. Only thing that makes me keep switching it out is that I cant get used to the forward mounted sensor. I prefer them in the middle but its such a superb mouse that I always come back to it more than the others I own.
VulcaN
Another G700 vote, works a treat with zero perceptible lag.
The only reason to spring for the G700s is if your a heavy gamer and will wear through the life of the buttons faster, but it seems like you will just be using it at a friends house so you dont really need those upgraded components.
soulwatch5
I personly would stick with wired for gaming. I use to have a g700 but it would randomly lag while in games. Didn't happen often but when it did it was really annoying. Then again after reading a lot of the posts above I guess I just got a bad mouse.
