Wireless gaming controller
Pivo504
I'm looking for a wireless gaming controller that I can use on my pc and my android phone
Ps 3 dual shock will work with pc android and dolphin as well & wireless ?
Well I just want one controller that can work on Pc games, dolphin emu,and android emulators? What would be best and wireless to? Appreciate the help
define: "Wireless", there's something like the Logitech F710 but would need a usb utg cable to be usable on an android device.
There's basically only two wireless variants for PCs, dongle based ones (the aforementioned logitech, the 360 controllers w/ dongle, etc..) or the PS3 controller that can be eventually persuaded to work via bluetooth. (bit of a royal pain to get going, doubly so on android and support isn't fully there)
What is better out of the 360 and the Logitech for android,pc,and dolphin emulator? Can they both work well with all three? Also I got a utg cable already
Which is better out of the 360 and the Logitech wireless &can both be used with android, pc,and dolphin emulator? I also have a utg cable
Either will work man. If you Google either controller with the additional search terms of "android" or "Dolphin emulator", you can easily found directions to set up either controller on Android or Doplhin emulator. See for yourself.
Thanks for the response dang. But just trying to find out which controller is best out of the two bc I've read several mixed reviews. If anyone can chime in I would appreciate it
The reason why there are mixed reviews is because there are mixed opinions, nothing more.
I'm perfectly happy using my 360 controller for PC and Dolphin emulation etc.
Where did you get yours horror show? Does buying the controller come with everything needed for wireless?
Only if you buy the Xbox 360 for Windows version. The regular wireless 360 is unusable in Windows without the purchase of a 3rd party wireless receiver.
FWIW, I have had very little issue using my Xbox 360 controllers with Steam Big Picture on my HTPC. Had to buy that 3rd party receiver though.
Dang if I get the 360 windows version will it work with android phone with utg cable and also work with dolphin emulator?
